The relax function on my Versa stopped working. I click on it and it starts to load, but it just returns to previous screen. I tried restarting my Versa, it didn't work. Help! I need to relax. 🙂
Hi @Kcjam1, welcome to the community.
Have you tried uninstalling the relax app and then installing it again? You can do this by following these steps -
Open the Fitbit app on your phone - tap your profile picture - tap on Versa - tap on the "Apps" tile - Make sure "My apps" is selected - scroll down to "Relax" and tap on it - tap the pink "uninstall" button.
Once you've done that I'd suggest restarting your Versa by following the steps here. After you've done that repeat the above but select "All apps" instead of "My apps", then use the search function to search for "Relax" - proceed to install. Hopefully it will work properly now.
