05-22-2019 11:06
05-22-2019 11:06
Is there a way to remove calories burned from the "Layers" clock face and replace it with a different stat, like flights climbed or active minutes? That's my favorite clock face, but I would much rather have a different stat be the third one on the screen. Only solution I can find is to choose a different clock face that only shows two stats instead of three.
05-22-2019 11:34
05-22-2019 11:34
Hi @pjwshlst - If you open the Fitbit app on your phone and select Account -> Versa -> Clock Faces -> My Versa, you can check for a gear icon. If you see one, that should take you to settings where your will see if that clock face can be edited. I don’t use Layers, myself, but what I describe is typical for most clock faces. Hope this helps.
