I purchased the Real Weather App by Renno. The clock keeps giving me the message "This app requires the internet permission to be granted. I have tried removing the watch face from the Fitbit app and reinstalling like I was told to get the permissions tab to reappear and it will not work. Also the clock will not removed itself from my watch even though I have put 5 other faces on the device. I need assistance.
Hi @user121456 , go to clocks and at the bottom you will see your installed clocks. If the Real Weather app is one of them, press and hold it untill a popup will show to delete the CF and press delete. If the Real Weather app is not one of them, cause your already installed 5 CF's, remove one or more CF's in the same way untill you see the Real Weather app and act like described above. Regards kuzibri
BTW, if you install a CF which shows the weather, make sure that the API/provider of the weather is Accuweather, cause that;'s the one Fitbit uses.
