01-20-2020 05:46
01-20-2020 05:46
Hi all,
I recently had an issue with my original Versa where it stopped syncing to my phone and Fitbit sent out a replacement device just over a week ago. The replacement Versa syncs up to my phone as expected and everything appears to work now, which is great, however I've noticed a massive drain on the battery life where I'd be lucky if it lasts a full 24 hours.
I've looked at numerous topics regarding battery life and have made the following changes to the Versa and Fitbit App -
- Turned off All Day Sync
- Reduced notifications from numerous apps to my main phone/text/email/Whatsapp
- Using a Fitbit clock face
- Screen brightness set to Auto
- Screen Timeout set to 10s
- Sleep mode scheduled from 11pm - 8am
Is there anything I'm missing that may be causing a massive battery drain?
01-20-2020 07:55
01-20-2020 07:55
Which battery are we referring to @Dbrowne88. they phone's battery or the Versa's battery.
Best Answer01-20-2020 08:13
01-20-2020 08:13
This is the Versa's battery. Since initial post, I have also dimmed the screen and turned off quick wake.
Best Answer01-20-2020 09:17
01-20-2020 09:17
Since it was recently replaced. Have you contacted Fitbit to have this issue documented?
Best Answer01-20-2020 15:57
01-20-2020 15:57
No not yet, I wanted to check in here first just to see if there was something obvious I might have missed.
