07-02-2018 08:01
07-02-2018 08:01
Who on earth designed the bands for Versa......should be sacked!!! why they didn't stick with the same fixings as the Charge 2 is beyond me they were a good solid easy change fix, the Versa is an absolute nightmare.
Best Answer07-02-2018 08:08
07-02-2018 08:08
Stick with it, it does get easier the more you do it.
07-19-2018 14:09
07-19-2018 14:09
Hello @FoxyDragon, glad to see you in the Fitbit Community!
The way that the Fitbit Versa was designed was to make the watch more secure for those who do more heavy exercise. To help you get better at putting on your bands, here are a few tips; make sure the watch face is facing down, when installing the bands, hold the bands at a 90 degree angle, use your finger to push the pin in, then at 90 degrees push it in with your thumb.
Did I solve your problem? Mark it as solution!
