05-02-2019 12:36
05-02-2019 12:36
Need help replacing my Charge HR with my new Versa. Instructions?
05-02-2019 12:40 - edited 05-02-2019 13:33
Hi, could you be a bit more specific what kind of help you need?
EDIT: if you need help setting up you Versa, the first thing you have to do, is unpair and remove your Charge HR from the Fitbit app. Logout of your Fitbit account after that, restart your phone and login again on your Fitbit account. After that setup your Versa to your phone in the usual way as you did with your Charge HR. You know how to setup a Fitbit device.
Best Answer05-02-2019 16:22
05-02-2019 16:22
Good advice, @SunsetRunner . But may I add one more thing for @caat? After removing the Charge HR from your Fitbit app, go into your phone’s bluetooth settings and give the command to Forget the Charge HR.
