10-08-2019 06:38
10-08-2019 06:38
I bought a versa second hand but can’t operste it because screen keeps asking me to connect a phone as it’s locked and I do t gave the four digit number it requires.
can I reset this in some way?
thx
10-08-2019 09:29
10-08-2019 09:29
Hi @SunsetRunner , you can try to reset it with the three buttons method: press and hold all three buttons together untill you feel a strong vibration (make take while). If you feel that, your Versa has been reset to the factory setting. Good luck, regards kuzibri
