10-25-2019 10:37 - last edited on 10-27-2019 14:15 by LiliyaFitbit
Good morning, my versa locked into the watch and it’s asking me reset via phone, the problem is I deleted the device via the app so I could add my new device.
I have tried multiple times to reset it but it’s not working because it’s screen is locked...
many other advice?
10-27-2019 17:26
10-27-2019 17:26
Hi @Morningperson01, thank you for your reply.
I appreciate your troubleshooting efforts. Since the steps you tried didn't work, I've gone ahead and escalated your case to our Support team, for them to take a deeper look at this. Please keep an eye on your inbox.
10-27-2019 14:14
10-27-2019 14:14
Welcome to the Fitbit Community, @Morningperson01. I am sorry for the delayed response.
I appreciate your participation in the Forums and sharing the issue you're experiencing with your Fitbit Versa being locked. Thank you for your efforts to resolve this. I recommend doing a factory reset. Please note that you'll need to reinstall any apps on your device after the reset, and if you couldn’t sync your device, then any data on the Fitbit device will be lost. In order to do the factory reset, please do the following:
Let me know how it goes, I'll be around.
10-27-2019 16:05
10-27-2019 16:05
I have attempted this already but because the device is locked and need to be unlocked via the app I cannot do as I removed the device from the app. Now I have no way of syncing back together because it’s locked
10-27-2019 17:26
10-27-2019 17:26
11-07-2019 07:02
11-07-2019 07:02
I bought Fitbit versa throughAmazon. Unfortunately it’s locked. In order to solve it, I uninstalled the app. Now I can’t connect the watch to phone. Phone sending the pin but I can’t see in watch because it’s locked. Kindly advice. Tried to contact customer care n. Fitbit support but not able to find solution. Kindly advice
11-07-2019 15:16
11-07-2019 15:16
Welcome to the Fitbit Community, @Suchithrashenoy.
I appreciate your participation in the Forums and sharing that your Fitbit Versa which you bought from Amazon is locked. Thank you for your efforts to resolve this and contacting our Support team. I would like to confirm if you tried already to do a factory reset and then set up your device again?
You can find the steps to do a factory reset here.
Please keep me posted, I'll be around.
11-10-2019 03:48
11-10-2019 03:48
11-10-2019 13:03
11-10-2019 13:03
Hi @Suchithrashenoy, thank you for your reply.
I appreciate your efforts to resolve the issue and understand your concern. Since you've been working with our Support team already, I've sent this information to them and you should be getting a reply soon. I am sure they will try to help you in the best possible manner.
01-15-2020 23:02
01-15-2020 23:02
I cant seems to do this despite the tutorial. Is there a physical store that I can walk in to assist me?
05-19-2020 14:55
05-19-2020 14:55
7608412
05-19-2020 15:00
05-19-2020 15:00
Hi there,
I bought my versa in Feb 2019. Last week it stopped tracking my heart rate and sleep. I have spent hours resetting the watch, unpairing it from my iPhone, turning Bluetooth on and off, and reinstalling the App on my iPhone. It is stuck in the setup stage and has found the device but after hours still has not moved past the 'connecting to tracker' stage.
Can you please help?
