Samsung Note 9 newest software update
When I first got my versa on December 24, 2018, it worked just fine with my Samsung Note 9. However, I installed the newest software update on January 8, 2019 and afterwards, my versa still syncs with my Fitbit app just fine but notifications for calls, texts, and any enabled apps do not work. I realize Note 9 is not a compatible device just yet but it appears as though Note 10.1 is on the list so why is Note 9 still not added? Is there a way I can be informed of when the list is updated so I can finally start using my versa to its fullest extent? Seems a waste of money if I cannot utilize all of its properties and I find it irritating that Note 10.1 showed up on the list but not Note 9. Thank you!
3 REPLIES 3
I am having the same problems with my Versa and Note 9! Really like the Versa and Note 9 wish they would work together. So frustrating!
It is very frustrating that the Note 9 worked fine until the update. Of course, this happened after my return period on the Versa.
Knock on wood mine are working now! Hope it lasts!
