I am transitioning from a Pebble Steel which is failing. One of the features I most use on it is the ability to save preset countdown timers. A long press on upper right button brings up my 5 preset timers to quickly scroll through & select. Just got my Versa. I can only find a timer app that requires resetting timer value each time
Is there any app or shortcut that allows quick selection from a few preset timers?
@Kistewa It's great to see that you've visited the Fitbit Community! Thank you for sharing your idea about different countdown timers. You can add your idea in our Feature suggestions board. The more votes an idea gets the more likely the developers will try to implement it.
Let me know how it goes!
