07-30-2021
12:58
20:47
07-30-2021
12:58
20:47
Hello- I chose swim as exercise and then thinking it was good to go, did my swim. After swim the timer was still displayed, but it had a Lock on display and would not accept screen inputs even after dried. This feature makes it unless for multisport people. Seemed like my only recourse was to hold the input button until it went to factory reset...
Any way around this??
Thanks
This is doing nothing for my swim Lock.
Best Answer@Versa3Newbiee I think double press is a better description than double tap. Please make sure you feel the vibration each time you press the button. There seems to be a "sweet spot" in the timing. It might take 2-3 times to get that sweet spot.
Laurie | Maryland
The link I provided, will take you to a detail list of the steps needed to turn off swim mode.
