I've seen a few posts reporting this problem and, unfortunately, it doesn't seem to be repairable. If you are in Europe then you may still be covered by the warranty (where it runs for 2 years rather than 1). I'd suggest contacting customer support even if you don't think you are covered. They can check your warranty status and advise on your options: contact.fitbit.com
