Screen says data not cleared
My fitbitscreen says:
"Data not cleared
Sync&try again"
I did everything that I found on the net but nothing helps.
What can I do more?
5 REPLIES 5
Hi @sarurojo  You need to try  factory reset again. Can you get to your settings app on your versa? If you can scroll down to About and try a Factory Reset. Ifbthis doesnt help please come back here.
Community Council Member
Helen | Western Australia
Hi,
I can’t do anything.
On the screen there is a red cross and it says Data not….
I can’t change the screen.
Verzonden vanuit Mail voor Windows 10
I have flagged a moderator to come and help you
Welcome to the Fitbit Community @sarurojo. I'll be glad to assist you with your Fitbit Versa message inquiry.
Please restart your device and after that try to set it up as a replacement device.
Thank you for the heads up @NellyG.
Please let me know if you need further assistance.
I think the problem is that I can’t restart.
If I erase the fitbit app and in bluetooth and then I want to install again he doesn’t find the fitbit
