See time while tracking activity with GPS
ANSWERED
While I am walking/running with GPS enabled (Versa 3), the face always shows the GPS statistics, and there appears to be no way to get back to the default display without pausing or ending the activity. Am I missing something?
1 BEST ANSWER
Accepted Solutions
@RogerL50   You can't go back to the clock face while you are using the Exercise app, but you can see the time.  You can tap on the middle stat and it will go through available stats for that exercise, including the current time.  If you don't want to scroll through to see the time, you can set it as the top or the bottom stat.  Distance is the default top stat and elapsed time is the default stat in the Run shortcut.  You can change either one to be the current time, if you want.
To change the stat you see, please do the following.  Select Run, then swipe up on the tiny "^" at the bottom.  Swipe up to the Show Stats section, then customize it.  You have to repeat this in the Walk shortcut.  Any custom settings are for that shortcut only.
Laurie | Maryland
2 REPLIES 2
Laurie | Maryland
If I remember correctly all you need to do is swipe the screen from left to right while using the gps feature, each swipe shows a different item and the clock will show after a swipe or 2. Good luck.
