05-07-2020 03:51 - last edited on 05-07-2020 20:00 by LiliyaFitbit
How to set time on my fitbit
05-07-2020 04:05
05-07-2020 04:05
You can't manually set the time, but it should reset itself whenever it syncs to your phone or computer based on the time on that device. Does your fitbit seem to be syncing ok?
The other thing that affects the time is the time zone in your profile. You can check yours at https://www.fitbit.com/settings/profile If you do change it then you'll need to sync again to update your fitbit.
Best Answer05-07-2020 04:09
05-07-2020 04:09
