03-12-2020 16:11
03-12-2020 16:11
Did a factory reset, then deleted my device. However, I'm not able to set it up again on my Mac because the Versa 2 is not among the options. All there is is the Ace and the Aria scale. So how can I set up the Versa 2 again? Or is it toast?
03-13-2020 02:05
03-13-2020 02:05
I wonder if the rules have changed since you first set it up as fitbit now say:
"You can't set up Versa 2 on a Windows 10 device. Use a compatible iPhone, iPad, or Android phone."
taken from: Help article: How do I set up my tracker?
Do you have access to a phone or tablet to set it up?
Best Answer03-13-2020 03:22
03-13-2020 03:22
No, that's not it. You can set it up on a Mac. But the link you posted sent me to the same place that only allows the Ace or the Aria.
