Settings button isn't working on Versa
ANSWERED
When I touch the settings button on the watch itself, it acts like it’s going to open but goes to the clock screen.
1 BEST ANSWER
Accepted Solutions
That sounds weird! Try restarting your Versa several times and see if that fixes it. If it doesnt try a factory reset - you will have to use the button method if you cant open the Settngs app though! Let us know if either of these help.
Restart your tracker
FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up.  Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Community Council Member
Helen | Western Australia
4 REPLIES 4
Restarting it worked!!  Thanks!  🙂
Great to welcome you @Cathpin71 and @NellyG thanks for stopping by.
I am glad to see here that the instructions provided by our friend worked and that your Versa is now working properly. If you need anything else, do not hesitate to post it.
Keep the stepping up! Man Happy
literally nothing works because I tried everything here and executed it perfectly, and the white icon is there along with the battery icon on the top left corner.
