02-04-2019 09:46
02-04-2019 09:46
Is there a way of disabling the sickscore? I absolutely loathe this "feature" and it seems to be completely pointless.
As an example, the sick score in my area constantly shows as 97 or more, but when I was in the UK last week, it was generally 32 or less.
I see no point in this app, and would be delighted to do away with its constant reminders
Best Answer02-04-2019 10:45
02-04-2019 10:45
Hi @KaptainVersa and welcome to the forums. I searched thru the Fitbit Help pages but could not find anything on Sick Score. Perhaps auto correct typed something different than what you wanted?
Best Answer02-04-2019 10:46
02-04-2019 10:46
Hello @KaptainVersa. Welcome to the Fitbit forums.
I don't get any sickscore on my Versa. Are you seeing it on the Versa itself, or on your phone's app?
I expect this is coming from some app, which you can disable. From phone dashboard, click Account icon near top right, then Versa. You will see a tile labeled "Apps". Click that. Look through the apps under "My Apps" for some app you might have installed, or that looks like something that might give a sickscore. Then click on it and probably have the option to uninstall.
Best Answer02-11-2019 01:44
02-11-2019 01:44
I am also trying to disabled it but I don't know how to. Its a little bit annoying.
Best Answer02-11-2019 02:25 - edited 02-11-2019 02:28
I think you may be referring to the Achu sickness prediction clock face or Sickweather clock face? Simply change your clock face to a different one and you should stop receiving the daily check in reminders.
02-11-2019 06:28
02-11-2019 09:12
02-11-2019 09:12
Welcome to the Fitbit Community @Nooshka! Thanks for sharing the issue that you are experiencing, I would like to know if you were referring to the Achu sickness prediction clock face or Sickweather clock face as @N8teGee kindly mentioned? If you're talking about another issue, can you please provide some screen shots, they will be handy to provide you with an accurate response and give you a solution. Just in case here is the link on how to add images to your post.
I will be waiting to hear from you, please let me know if you need anything else! ![]()
@KaptainVersa can you please confirm that you were talking about the same thing? and if your issue got solved?
Thanks a lot @SunsetRunner, @JohnnyRow and @N8teGee for your intervention! ![]()
05-24-2019 07:37
05-24-2019 07:37
Hello!! i tried to use the Achu Clock face but it is impossible to log in.
I tried many times and i still cant!
Best Answer05-24-2019 14:29
05-24-2019 14:29
Hi @marinadsvillela. That clock face was developed by a third party developer, not Fitbit. You can can contact them at support@achu.ca
They will be better able to help you.
Best Answer12-26-2019 18:16
12-26-2019 18:16
Useless function of sick score..
every time show and make the clock fonts became small. It is hard to see the clock. So every time have to touch the screen to skip the sickscore. It is a Sick of function and stupid.
Best Answer12-28-2019 13:19
12-28-2019 13:19
@scottchuan - If sick score is a clock face, then change to a different one. That’s the beauty of having so many beautiful and functional clock faces.
10-11-2021 17:32
10-11-2021 17:32
How do I get a sick score
