04-28-2021
15:22
20:47
04-28-2021
15:22
20:47
Hi
I had a Versa 2 had problem with inconsistent sleep tracking, so i went back to the retail outlet i brought it off had replaced with the versa 3, had it about 3 weeks and its just as as bad
Every model I've had - charge, charge 2 charge 3,versa lite.
It's time this with problem is sorted. When you have Sleep Apnoea its frustrating.
Done the resets, changed to sensitive is just as bad!
Nandad
04-29-2021 06:01
04-29-2021 06:01
As quoted on the Fitbit site you need a certain amount of good sleep for it to do a good job.
That said, there may be a glitch in the App, so it is recommended to
In Android phone Settings * Apps Fitbit Storage - clear cache [not data] Force Fitbit shutdown [though it doesn't seem to fully] Log back in to the Fitbit app
*Quick Shortcut: Press and hold the Fitbit launch icon, then App info [on some phones] |
Or for IOS uninstall/reinstall the Fitbit App, and redo notification setup. |
And also a good idea to restart both phone and watch to ensure optimal conditions.
05-16-2022 16:24
05-16-2022 16:24
Hi
I go to bed around the same time every night and wake up the same time: 10.15pm - 7.00am.
I'm 66 years old I'm not tec savvy.
I rebot my watch on a regular basis.
Alot of instruction i don't understand, not everyone is tec savvy.
There needs to be a fix it manual with pictures, I'm dyslexic.
