01-12-2019 03:02
01-12-2019 03:02
I upgraded to a Fitbit Versa just after Christmas from when I bought it it wouldn’t pick up my sleep I’ve searched everywhere how to resolve this problem tried everything noticed it’s a big issue with the versa last night I put it on my wrist tighter and lower down hey presto this morning it had picked up my sleep anyone else with problems try this I know it’s only once but it’s never worked since I bought it I will keep you informed
Best Answer01-12-2019 03:12
01-12-2019 03:12
Hello , mine worked for just two days and stopped after then , I don’t know what to do ,
how are you doing ?
Best Answer01-12-2019 03:24
01-12-2019 03:24
Hi I’ve noticed that since I tightened it last night my heart rate is always showing unlike before I will keep you posted how things are going did you put it on tighter
Best Answer01-12-2019 06:29
01-12-2019 06:29
Did tightening the band fix the sleep issue?
Best Answer01-12-2019 10:27
01-12-2019 10:27
Hi it looks like it it's only been one night but it's never recorded my sleep in th time I've had it give it a go ill keep you informef
Best Answer01-13-2019 14:22
01-13-2019 14:22
Since tightening my fitbit it's tracked my sleep for two nights will keep you posted
