01-17-2020
08:10
07:58
01-17-2020
08:10
07:58
@SunsetRunner Welcome! It's good that the community is growing!
Let me help you with your inquiry. Although the phone isn't listed as compatible it doesn't mean that it won't work with the Versa 2. Still many stores offer a return window and the fitbit.com store has a 45 days window to return your product so you can try it out and see if it works for you.
I also moved your post to the correct board.
Let me know how it goes.
Best AnswerYes it did work. Sometimes the notifications will not work randomly and you have to restart your phone but that's the only problem I've had with it. Other than that it works perfectly fine with the Sony Xperia 10 plus
