01-02-2020
08:51
19:28
LizzyFitbit
01-02-2020
08:51
19:28
LizzyFitbit
Hello,
When I want to control my spotify via my Versa 2, it keeps disconnecting. Everytime I need to go into the Spotify app in the Fitbit app and reconnect my premium account. This is getting SUPER annoying! Is there any way to ensure that my spotify account stays connected?
Thanks!
01-12-2020
20:02
07:29
01-12-2020
20:02
07:29
Hi @queenkala. Welcome! It's great to see a new face around. I'm sorry for the delayed response.
Thanks for bringing this to my attention. I understand how you're feeling about this matter and I'm sorry that you're having this experience. I'll be here to help you with this. Just to confirm, is the issue just with the connection or does the Spotify app also revert to a free version instead of Premium?
There are some factors that may prevent the Spotify app to work correctly, so make sure:
That said, if you've not done so I'd recommend to remove your Versa 2 from the Bluetooth settings, reboot your phone, restart your watch, sync with the Fitbit app and try using the Spotify app to monitor its behavior.
Best AnswerI am currently experiencing the same problem. I have completed all the steps you (moderator) mentioned several times. Still the problem persists. I am close to returning my fitbit to the store.
01-16-2020
19:57
07:28
01-16-2020
19:57
07:28
Hi @SunsetRunner. Welcome on board.
Thanks for sharing that you're having the same behavior with your Versa, as well for trying the steps posted above. I'm sorry that you're going through this situation and let me continue helping you. To further investigate, may I know if you're having connection issues with the Spotify app on your watch? Or is the issue with the Spotify app reverting to a free version instead of Premium?
