Step Count
ANSWERED
 I just recently noticed that when I move my arm, my step count increases.  I do have it on my non-dominant arm and my settings reflect that.
It seems like that should not be the case.  I was sitting at my desk stuffing envelopes and each time I moved my arm, my step count increased.
1 BEST ANSWER
Accepted Solutions
Hi @liljen61 Wrist worn trackers all rely on arm movements to count your steps, so there will always be some extra steps counted when you are using your arm. Usually over a days stepping the number is insignificant, and really doesnt affect your measurements much. If you are getting thousands when you are not walking there might be a problem with the tracker. In case it is glitching, try restarting your Versa several times and see if that helps. There are some activities that count many steps for different people so if you are doing one of these it is probably easiest to remove the tracker while you do the activity (I have seen reports of both guitar playing and drumming counting thousands of extra steps, along with other activities at times)
Restart your tracker
Community Council Member
Helen | Western Australia
1 REPLY 1
