05-02-2018
12:11
17:57
EdsonFitbit
05-02-2018
12:11
17:57
EdsonFitbit
Anyone had an issue with the fitbit display screen showing one number but if you go to the step count breakdown, the numbers do not match? My fitbit shows one number, the dashboard shows the same number but when I go to the actual breakdown of steps it is off by over 1500 steps
Moderator edit: added label
05-02-2018 13:49
05-02-2018 13:49
Some clock face developers use "localized step count" which was actually addressed by someone before. The Fitbit step count uses an algorithm to make step count more accurate on wrist bases devices.I'd recommend you use another clock face,
Hope I helped!
