02-19-2019 08:23
02-19-2019 08:23
So today I've done 5000 steps according to my Versa, but when syncing to my app it says only 2700???
Best Answer02-19-2019 12:24
02-19-2019 12:24
@Cerriann1t Try syncing again and check the sync time stamp (open fitbit mobile app, tap on the Versa icon, scroll down to the sync section) to see if it synced properly. It may need several syncs. Also, it's a good idea to go to your Dashboard on Fitbit.com to make sure all the data is there.
Best Answer02-19-2019 16:02 - edited 02-19-2019 16:04
It is insane and unacceptable that a watch can't keep track of time. Is thing something support has noticed engineering about? It seems like a simple fix would be to either have watch have a time setting or automatically sync with phone. The current approach does not make sense in any scenario
Best Answer03-01-2019 10:18
03-01-2019 10:18
@Cerriann1t Did you manage to make it work?
@dtrailin There is an automatic sync. It's called All-day Sync. You can enable it in the Fitbit mobile app.
