02-19-2020 06:35 - edited 02-19-2020 11:45
This morning I was sitting down when suddenly my fit bit was telling me that I got a new badge for getting 65 000 steps in a day. When I checked both the app and my versa watch they are both reading as having over 68 000 steps. Which I had only been awake for a little over an hour at that point and would have had maybe about 200 steps. Is there a way to fix this, I'm part of a Valley Loop Challenge currently that it says I've won now if that helps identify a glitch maybe?
This is the first time this has ever happened and I've had my versa since end of August 2019. I use a Samsung S9.
02-20-2020 10:45 - edited 02-20-2020 10:47
Welcome to the Fitbit Community, @KaitlinMarie27.
I appreciate your participation in the Forums and sharing the details of the accuracy issue you experienced with your Fitbit Versa. Thank you for providing the additional details. I understand your concern as you're part of a Valley Loop Challenge currently and recommend removing the extra steps from your daily total by following the instructions in this help article: How do I delete steps and floors in the Fitbit app?
I have also sent your information to the Customer Support team so they can get in touch with you and provide further assistance. You should be getting a reply soon.
Let me know if you have any questions.
Best Answer02-20-2020 10:45 - edited 02-20-2020 10:47
Best Answer08-06-2020 05:37
08-06-2020 05:37
Hi,
I'm having same issue with my Versa today. I was sitting in the morning and suddenly the steps went to 17K with no movement at all. Is there a fix for the app?
Thanks.
08-06-2020 15:24
08-06-2020 15:24
Welcome to the Fitbit Community, @lola20.
Thank you for joining the thread and sharing that you're experiencing the same issue. I appreciate the additional details and I am here to help. I recommend restarting your watch by following the steps from this help article: How do I restart my Fitbit device?
Additionally, I recommend checking if your Fitbit app is updated to the latest version as updates come with new features and bug fixes: How do I update the Fitbit app?
Let me know how it goes. I'll be around if you have any additional questions.
Best Answer07-29-2021 12:46
07-29-2021 12:46
Same problem happened to me several times now, despite the Versa being updated and also restarted several times. Something is definitely glitching, which is a shame, because it renders my stats completely useless.
07-29-2021 16:59
07-29-2021 16:59
It’s good to see you in the community, @JaxMax.
Thank you for joining the thread and sharing that you're experiencing the same issue. I understand how you are feeling and appreciate your troubleshooting efforts. I recommend confirming if you have MobileTrack paired to your Fitbit account. MobileTrack lets you use the Fitbit app without a Fitbit device by using your phone's sensors to track basic activity data including steps, distance, and calories burned. For more information, see How do I use Fitbit MobileTrack? MobileTrack may add extra steps and I recommend removing it from your Fitbit account if you're not using it: How do I remove a Fitbit device from my account?
Hope this helps.
Best Answer01-08-2022 15:14
01-08-2022 15:14
Mine clocked 32,000 steps today with very little movement, I have re set, re installed but the stats are still at 32,000 😭
06-28-2023 07:35
06-28-2023 07:35
Same problem here, and same problem all over the Fitbit forums and they never have a better answer than to restart it or check your settings. Obviously, relying on a Fitibit to count steps is a bad idea because it's completely inaccurate an always will be.
