10-25-2018
15:25
09:19
HeydyF
10-25-2018
15:25
09:19
HeydyF
After using my new Versa with no problems for 5-6 days, it suddenly began recording the times that I fall asleep inaccurately. I usually go to sleep around 10-10:30 PM but for the last three nights it shows data only from 3AM until I wake up around 6 to 7 AM and in one case ended abruptly after a few hours. I can't seem to find a way to correct this by changing settings. If it were a computer, I would reboot it but I hate to lose any data that has not been saved. Recommendations will be greatly appreciated.
Best Answer10-26-2018 09:21
10-26-2018 09:21
Hey @blondlady, it is great to see new members around! Let me give you a hand on this, please restart your Versa by following the instructions in this post. Don't you worry, because the restart won't delete any data from your Versa. Then wear it for a few nights and let me know how it goes!
I'll be around!
Best Answer10-28-2018 10:39
10-28-2018 10:39
Thanks for you suggestion. I tried it and you were right that data was not lost but it didn't fix the problem. I realized that I had started wearing my Versa in one looser notch on the wrist band. When I went back to one tighter notch, the problem disappeared. So, I was loosing contact with Versa during the night. Thus, the sleep data was actually not recorded during this time.
Best Answer10-28-2018 21:11
10-28-2018 21:11
I’m actually sorry to hear this. I’m having the same problem, I’ve tried the same things but I don’t have a simple answer (although I checked just in case.)
Best Answer10-29-2018 08:05
10-29-2018 08:05
Best Answer10-30-2018 11:12 - edited 10-30-2018 11:13
Hey @blondlady, thanks for your response! Sounds great that your Versa is tracking your sleep stages now. I appreciate you have followed the tips I posted about wearing it tighter, so it can get better heart rate readings.
@FidsLady, welcome aboard! Did you try to wear your Versa tighter? If you haven't please give it a try. Also. I'd like you to review the factors that might be affecting your sleep stages, in this helpful article.
Let me know the outcome guys!
Best Answer01-01-2019 10:38
01-01-2019 10:38
This is a known issue with the versa. There are several threads on here about inaccurate sleep tracking, missing chunks of sleep or missing detailed sleep stages. There has been no fix for it and none of the strategies proposed by moderators work for many versa users. I'm seriously considering returning mine because sleep tracking as the main feature I appreciated with my blaze, which worked great for over a year.
05:06
09:02
01-02-2019
05:06
09:02
Hey @Jerimennifer, it is great to see you around more often! I'd like to further assist you with this, so I'd like to know if you have tried the tips in this help article: What should I know about sleep stages? to improve your sleep and sleep stages tracked. However, if the issues persist, I can go ahead and escalate your case with our Support team so they can further assist you.
Keep me posted!
Best Answer01-02-2019 08:52
01-02-2019 08:52
Best Answer01-02-2019 09:44
01-02-2019 09:44
Thanks for your response Jenmenifer. After struggling with this issue for a couple of months, I believe the problem is mechanical rather than electronic or digital. In my case, the Versa is just too big for my wrist. I am a small women 5'3" and about 110 lbs. Not only does it look funny stylistically but I think it is the cause of my problem.
I am a restless sleeper (hence my interest in tracking my sleep patterns in the first place) and I believe that sometimes the Versa edges or band gets caught in the sheets disengaging the back of the devise from from my wrist, which interrupts the recording, which may or may not reengage later resulting in an incomplete record or worse yet two separate records for one night. I wear it with the band as tight as I can and have the excess tab secured near the end by the loop/prong devise on the band. In my case, the data seems to be lost and can't be recovered by resetting the sleep times. Maybe this explanation will be relevant to some of the many others who have had the same experience.
I am very disappointed in the Versa because I had such a good experience with an earlier Fitbit model that slipped into a small pocket on a small wrist band. This has been an expensive experience and the Versa is now occupying a spot in my jewelry box.
Best Answer01-06-2019 23:35
01-06-2019 23:35
I replied to your post, but didn't hear back. Oddly, the sleep tracking seems to be working the last few nights, but I and concerned that I may keep it beyond when I can return it to the seller and that the problem will continue.
Best Answer01-07-2019 01:51
01-07-2019 01:51
Did you try it on your opposite wrist? I have had mine two weeks and am still debating on whether I should keep it. But it had issues recording sleep on my one wrist but works fine on the other. It is a pain switching it over at night, but worth it. I have also seen bands that are all full of holes which can be made smaller, maybe you could find one of these?
Best Answer01-07-2019 08:33
01-07-2019 08:33
Thanks for your suggestions! I wear it as tight as I can stand it (the 3rd tightest hole in the standard Versa band but I haven't tried my dominant hand. I'll let you know how it works.
Best Answer01-07-2019 08:34
01-07-2019 08:34
Sorry, but I don't see another response from you yesterday. Can you send it again. Tx
