04-27-2018
12:36
17:01
EdsonFitbit
04-27-2018
12:36
17:01
EdsonFitbit
I bought the new Versa this morning having had the Alta for nearly 2 years. So far I've had most of the issues that other people have had including the sync and notification problems. The Alta was faultless with notifications but the Versa is hit and miss. I've factory reset it twice and removed the Alta from the Fitbit app, have got to a stage where the sync seems to be ok but the notifications arnt. The phone had been sat at the side of the Versa whilst it's been on charge and received some notifications and not others. This is a big let down compared to the Alta as it's one thing I use alot whilst out doing my daily job. I'd like to think this is going to be sorted, if not it's going back
Moderator edit: added label
04-30-2018 10:45
04-30-2018 10:45
Hello @KezzaRed, I hope you're doing well, it's great to see you around. ![]()
I appreciate you have brought this syncing and notifications issues to my attention and I would like to thank you for mentioning the troubleshooting steps you've already tried in hopes to resolve this situation.
When it comes to the syncing issues, I would like to suggest you to check the following:
If your device still won't sync, try these steps:
Now, when it comes to Notifications, have you checked if your Versa is not currently on the Do Not Disturb Mode? You can check press down the button on the left for 2 seconds. If Do Not Disturb is enabled you will see the OFF option selected under Notifications. However, if everything seems right with your tracker I would like to suggest you to reset Notifications from the Fitbit app following these steps:
- Go to the Bluetooth settings on your phone and tap on tracker. Then tap on Forget this Device.
- Force-close the Fitbit app by double tapping the home button on your phone and swiping up the app.
- Open the app again and tap on Account > Your Tracker > Notifications. You will receive the following Pop-up:
- Then, once you tap on Set Up, the app will begin setting up your tracker with the Bluetooth on your phone, which will prompt the next pop-up:
- Tap Pair
- Once you get back to the tracker options, tap on Notifications an enable the ones you'd like to receive.
I hope this can be helpful, give it a try and keep me posted in case you need anything else. ![]()
04-30-2018 10:54
04-30-2018 10:54
04-30-2018
20:19
09:01
MarcoGFitbit
04-30-2018
20:19
09:01
MarcoGFitbit
Hold the left button down until you see the notifications tab.
My wife had her notification tab clicked on off and simply changed it to on and works like a charm.
Best Answer05-01-2018 04:48
05-01-2018 04:48
Hello @KezzaRed, I hope you're doing well, thanks for taking the time to reply. It's nice to see you around too @blu-steel, thanks for your insight about this situation. ![]()
@blu-steel, I appreciate you have shared some troubleshooting steps with us, I'm sure they will be very helpful for other members of the Community facing the same situation.
@KezzaRed, I appreciate you have come back and let me know things seem to work better. I'd like to thank you for sharing your findings when setting up a new device and would like to suggest you to only restart your Versa by pressing and holding the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen if you come across an issue with Fitbit Pay again.
Thanks for your patience, if there's anything else I can assist you with, please feel free to reply.
05-01-2018 05:19
05-01-2018 05:19
Best Answer05-02-2018 04:36
05-02-2018 04:36
Hello @KezzaRed, I hope you're doing well, thanks for taking the time to reply. ![]()
I appreciate you have you have reported your transactions did not show up in the wallet app. I'll make sure to forward this information to our team so they can take a better look at it, please feel free to reply if this happens again.
Thanks again for your report, if there's anything else I can do for you, please feel free to reply.
