05-18-2019 01:35 - last edited on 05-19-2019 19:55 by LiliyaFitbit
Hi all I have a Huawei honour 8x and was wondering if anyone has got it to connect to the versa?
05-18-2019 17:14
05-18-2019 17:14
@Mart24 Have you tried installing older version of Fitbit app, like 2.74.2? Look for it on the internet.
The trick here is to not pair in phone Bluetooth settings but rather let the Fitbit mobile app do that.
Additional tips if sync issues persist: If you have Wifi set up, go to Fitbit mobile app and remove it, then sync your Versa. I noticed that it causes issues for me. If you have other Bluetooth devices paired with your phone, forget them. One of them might be causing issues. Also, make sure Always Connected, Keep Alive Widget and All day sync are enabled.
05-19-2019 19:54
05-19-2019 19:54
Hello @Mart24 thanks for joining the Fitbit Community, it's great to have you on board! It's nice to see you around @Marrrmaduke !
@Mart24 let me assist you with your inquiry about syncing the Fitbit Versa with your Huawei Honor 8X. While your phone is not a supported device for the Fitbit app at this moment, it doesn't mean that it won't work with the app entirely, but rather that some of its functions might work intermittently. Our engineering team works really hard to keep up with every new phone and mobile device releases, so our customers can enjoy their trackers to the fullest. I recommend keeping an eye on this page, as it will be listed there when your device is fully supported.
Have you tried what @Marrrmaduke suggested? You can double check the requirements and the troubleshooting steps in this help article: Why won't my Fitbit device sync?
@Marrrmaduke thank you for your helpful instructions!
Feel free to reach out if you have any other questions.
08-28-2019 09:24
08-28-2019 09:24
Has this been fixed? I have a Honor 8x and just bought a Versa - I'm so disappointed that there are these issues!!!!!!!
09-01-2019 19:50
09-01-2019 19:50
Welcome to the Fitbit Community, @korymumin1983 . I am sorry for the delayed response.
Congratulations on your new Fitbit Versa. Thank you for joining the conversation and sharing your feedback about syncing your device with Huawei Honor 8X. I totally understand how you are feeling. It's possible to come across some issues along the way since the phone is not a supported device for the Fitbit app at this moment. I appreciate your understanding while we work to improve this experience.
Were you able to set up your Fitbit Versa? I recommend checking these tips to improve syncing with your device: What should I know about using the Fitbit app on my Android device? Move on to troubleshooting steps if the issue persists: Why won't my Fitbit device sync?
If you have any questions, feel free to let me know.
06-01-2020 07:58
06-01-2020 07:58
Hi,
Had I read this before I would not have bought the Fitbit. Trust me its very sad that you buy something and it starts giving you problems. I have an Honor 8X for the last 1 year and I just bought a Fitbit Versa 2 Lite 3 days back. I am struggling to sync this **ahem** thing.
Please, someone, help me.
06-01-2020 08:39
06-01-2020 08:39
I am struggling. Please share the link to the older Fitbit version. I feel I should not have bought a Fitbit.
06-04-2020 04:07
06-04-2020 04:07
It is a pain to get your Honor 8X connected. I did not have any problems yesterday. There was a patch that ran on my Fitbit app on the phone and now boom the notifications stop working. Thank you, Fitbit for screwing up once again. I did not buy a Fitbit for £160 to keep doing this switch off and switch on. I do not know how it will get sorted.
06-04-2020 05:12
06-04-2020 05:12
@Sreeikanth we both have the same phone right, Honor 8x? The workaround I have described in my thread works every time for me, but it does need doing repeatedly, for me I do it in the morning when I wake up, and usually again in the late afternoon
06-04-2020 05:26
06-04-2020 05:26
Hi,
Great reply. Being a marketer myself I feel the most difficult thing for any brand to know about is the problem statement. Here you know what the problem statement is which is - Fitbit Versa not syncing with Honor 8X phones. What is Fitbit doing about it? By just asking us to read the Help does not help. I have been struggling with this and so are 1000's of users. Why cannot Fitbit come up with a solution? If you feel certain devices have a problem do insert a writeup when the user is shopping across various portals that these devices are not compatible with Fitbit. It will save you a lot of work.
Meanwhile rather than switching on and off my phone 100 times during the day, please come up with a solution and crack this code.
06-04-2020 05:41
06-04-2020 05:41
@Sreeikanth seems to me the issue is our phone is not fully supported so I guess we didn't research enough before dropping our £160 on this product 😥 that's the Fitbit explanation, as for what they are.doing about it, I don't know
So, are you saying the workaround which is working for me and my Honor 8x isn't working for you?it doesn't give you your notifications? When you're busy following the advice on the red warning in the Fitbit app about restarting and doing it 100 times a day does.that give you your notifications back? Because for me a simple restart as that notice suggests does absolutely nothing
06-04-2020 05:59
06-04-2020 05:59
I did what you asked me to do. Clear cache and it does work. You are right. We should have researched about it. I assumed (my fault) Fitbit works with all devices.
