01-08-2021 00:50
01-08-2021 00:50
Hello Fitbit community!
I would like to unlock my tablet automatically using my Versa2 watch via bluetooth.
When I search from the tablet the bluetooth devices, the versa 2 is not found. My wife's Mi band is always found.
The same when I search bluetoth devices from my smartphone.
Since I had always experimented problems with data sync from the Versa2 to my phone (the only way to sync the data is to manually start the sync from the app and most of the times I have to switch off and on the bluetooth from my phone), I am suspecting the watch is damaged, maybe the bluetooth is defective.
Do you experiment the same problems?
Is someone able to unlock an android device using the versa 2 bluetooth?
01-08-2021 02:38 - edited 01-08-2021 02:43
Hi @peregrinus are you able to load the Fitbit app onto you tablet? You should not be able to search for the Versa through the tablets Bluetooth. The tracker has to be paired by the Fitbit app, you can not pair the tracker.
The Fitbit app should be able to pair the Verses, then smart lock may be setup.
Now since you have a versa 2, you will be able to manually pair the Versa 2 classic to the tablet. Then use versa classic to unlock the tablet.
