07-10-2020 20:40
07-10-2020 20:40
How do you take the pin off the Versa 2
07-10-2020 21:49
07-10-2020 21:49
I looked it up on YouTube and they said
you have to reset your factory settings.
07-11-2020 07:01 - edited 07-11-2020 08:00
I haven't found a way, as @jadelia94 mentions other than a factory reset.
However @jadelia94 you can set the pin for Fitbit pay only. This way it is only when using fitbit pay that a user will be prompted to enter the pin.
