03-05-2022
03:39
09:09
03-05-2022
03:39
09:09
I can't clear my text if my watch. How do I reset my watch?
03-05-2022
04:08
07:05
03-05-2022
04:08
07:05
Hi @taylor427 - you can restart your watch with this procedure How do I restart my Fitbit device?
However, you can also do a full Shutdown from the watch Settings, About menu.
Wait at least 10 seconds for it to complete before placing on the charger to restart and charge it.
Also make sure you don't have a syncing problem, though the restart may restore syncing to work properly.
Best Answer03-05-2022 05:16
03-05-2022 05:16
I reset my watch now it won't turn back on. Uuugghhhh!!!!
Best Answer03-05-2022 06:40
03-05-2022 06:40
@taylor427- did you do a factory reset, if so there is sometimes a bug which can destroy the watch.
Best Answer03-05-2022 09:12 - edited 06-10-2023 10:44
Hi there, @taylor427. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. We‘re taking your comments and sentiments in regards to our products into consideration.
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help, please feel free to contact our team back so they can further help you.
