09-09-2019 15:11
09-09-2019 15:11
Hi, are Third Party Clock Faces compatible with the Versa 2? Or do I need to ask the developer to adjust his CF to the new Versa 2 resolution? Regards kuzibri
09-10-2019 04:31
09-10-2019 04:31
@SunsetRunner It looks as though it is available to install on Versa 2, I'm certain if it was not compatible it usually says unavailable.
09-09-2019 22:01
09-09-2019 22:01
The one I use was compatible. So the others should be as well. Also looks fine on my device
Wendy | CA | Moto G6 Android
09-10-2019 00:29 - edited 09-10-2019 00:34
Which clock face are you talking about @SunsetRunner, perhaps someone can check if it's available on the Versa 2 for you.
09-10-2019 04:09
09-10-2019 04:09
Thanks Nathan. The clock face I use is The One developed by Olbia Coding, so a Third Party One. Regards kuzibri
09-10-2019 04:31
09-10-2019 04:31
09-10-2019 05:11
09-10-2019 05:11
Thanks very much Nathan. Now it's possible for me to upgrade to the Versa 2 when it's available in my country. The compatibility of my clock face was a problem for me cause I use it already for a long time, is very beautiful and also very battery friendly, up to 6 days. Regards kuzibri
09-10-2019 05:54
09-10-2019 05:54
Excellent, I'm sure you will enjoy your new Versa 2 when it's available 😁
