04-05-2021 15:19
04-05-2021 15:19
I use my Versa 2 to track my running stats during football (soccer). I have the display set to show the time as I'm usually in charge of timing each player's turn in goal. Unfortunately, the time often disappears from the screen, even though the other stats are still displayed. Any ideas how to counter this. So far the only fix is scrolling through calories, Steps etc back to time or pausing then playing and the time reappears but this isn't conducive to focusing on the game as well.
04-06-2021 03:25
04-06-2021 03:25
Hello @Ipswichjon and welcome to the Help forum. The Versa 2 lets you customize the stats you display when you are using the Exercise app. The top and bottom stats have default settings, but you can change them. You can put the stat you need to monitor in the top or bottom and it will always be there. If you like having that stat in the middle, because you like the larger font, then edit out every other stat in the middle choice. It can't scroll if there are no other choices.
See p 47-48 of the Versa 2 manual.
Laurie | Maryland
04-06-2021 07:44
04-06-2021 07:44
That's really helpful, thank you.
Best Answer04-06-2021 08:21
04-06-2021 08:21
@Ipswichjon I hope I didn't give you incorrect information. I have a Versa 3 on my account right now and you can edit out the middle stat. I'm not 100% sure that you can do this on the Versa 2. But I hope I'm right.
Laurie | Maryland
