10-28-2019
07:12
09:24
DavideFitbit
10-28-2019
07:12
09:24
DavideFitbit
Just set up my Versa 2 last evening and it's 4 minutes behind. Is there a way I can reset that time? This drives me crazy.
Best AnswerNo, you can not change the time manually. You can try a Restart and see if that helps. Do it several times if necessary.
Best AnswerTry a Factory Reset by swiping left to Settings, then About, and then Factory Reset. If that doesn't do the job, contact Customer Support.
