Hi @SarahDobney What phone are you using? Is it on the Supported Devices List?
Try all the suggestiins in THIS Help Article on syncing problems
Helen | Western Australia
I am using iPhone 8. Been through it all with Fitbit. 3 versa doin the same thing. Must be a problem somewhere. Think I will have to look into another tracker. Don’t think it will be Fitbit this time.
Best AnswerAt 6:02PM, my Versa synced. At 6:05, I checked the time and it decided that it was 3PM, my heart rate was 160, and wouldn't sync. It's now not being detected at all by the app and phone.
A factory reset hasn't worked.
Best AnswerYa it’s done. If it is still under warranty they will replace it. If not u r on your own. Have done factory reset
wifi reset at home.
It just doesn’t work anymore. I have had 2 do this. So have to decide what kind of tracker to go with now. My last one was like 6 months old but they go with your original one for warranty so it’s done Fitbit is just not working with me anymore.
Best Answer@SarahDobney 🤣🤣 I hope you love your Versa 2 as much as I do!
