My Versa receives notifications from my Apple and Google calendars. Unfortunately, I'm getting multiple notices for the same calendar events, even for quite a while after the event had started.
I found a similar topic in the Blaze community forums from 2016, but the only answer provided was to dismiss the notifications from the phone itself. Is that really the only solution to this issue? If so, that's ridiculous. Please tell me there's a better solution than that by now!
@reidjw Welcome to the Fitbit Community! It's great to have you here! Sorry to hear about your multiple notifications. If you are able you could try syncing both apps and only use one as a notification option on your Versa. This way you won't have duplicate notifications. Additionally you could try disabling the notifications and re-enable them again.
Let me know how it goes!
