09-11-2019 08:29
09-11-2019 08:29
Is there an exercise shortcut for yoga for the Versa Lite? If not, how do I track yoga from my watch?
Best Answer09-11-2019 08:51
09-11-2019 08:51
Yoga is there as an exercise you can add to Exercise Shortcuts.
See How do I change or reorder the exercises in the Exercise app?
09-11-2019 08:51
Best Answer09-11-2019 09:36
09-11-2019 09:36
Oh! Thank you so much! I couldn't find how to add other shortcuts! This is exactly what I needed 😀 I appreciate it so much!!
09-21-2019 13:23 - edited 09-21-2019 13:35
UPDATE - I figured it out. In case it helps someone else, I was in totally the wrong screen. Make sure you go to your account page in the app and then select the device and then you will be in a customizable screen (it's the screen that has 6 boxes at the top with clock faces, app, etc). I think I was in a "start or stop the workout only" screen previously, even though it seemed just to be the right page.
Did Fitbit remove this feature of being able to replace one of the seven presets with yoga? When I go into my Fitbit app and go to the list of seven, I cannot change the order, nor can I delete anything. Am I missing something LOL?
Best Answer09-21-2019 13:40
09-21-2019 13:40
@tylerdurden8us wrote:...
If you already have all the slot filled up (7), you have to delete one before you can select which to add to take its place. I think it mentions that there at the bottom.
Best Answer09-23-2019 12:45
09-23-2019 12:45
Thankyou for posting this. It has helped me out too.
Best Answer09-23-2019 14:30 - last edited on 09-23-2019 18:46 by LiliyaFitbit
Thank you!
