11-06-2020 23:17
11-06-2020 23:17
hi I been running today but my fitbit versa 2 hasn't picked up all the calories I normally burn and not picked up all Distance either so it not tracking it properly. Is there a reason why it not picking up properly? I done the same speed and miles when running so I don't understand why it not tracking
11-08-2020 02:02
11-08-2020 02:02
Which mode did you use to record the run? Did you let Fitbit decide, or manually started the recording?
Did you get a map of the run?
Best Answer11-08-2020 02:09
11-08-2020 02:09
Best Answer11-08-2020 02:12
11-08-2020 02:12
I use the running mode i had on watch and It didn't show a map.
I ran this morning and it was fine I think I may had the watch on wrist to tight as I tightened it up in the week but I loosen it now and it was back saying what it should say
