Transfering music on Chrome OS Ver. 90.0.4430.218 64-Bit
(Versa 2)I'm using a Chrome OS  90.0.4430.218 Ver., but I can't seem to get the music to load, mine looks like a phone screen. Does anyone know how or why this is happening? It's like the screen got split in half and all of it got squished together.
3 REPLIES 3
Hi @melissaflowy - I’m not sure if there is a solution to your issue. Chrome is not one of the supported systems. Read here for more information. Can you possibly set your Versa 2 up to a mobile phone?
I might be able to a bit later. Thanks for the help.
@melissaflowy   The Fitbit Connect software that you need to transfer music is not compatible with Chrome OS.  It is only available for Mac and Windows.  Unfortunately, @SunsetRunner 's other suggestion won't help.  You can't transfer music from a mobile device.
Laurie | Maryland
