09-18-2019 17:55
09-18-2019 17:55
I just got the new Versa 2 today. When I went to add it to my app, it would only let me switch from my Charge 3, not add. Suggestions so that I can use both, depending on whether I'm exercising or not? Thanks so much!
09-18-2019 18:26
09-18-2019 18:26
Hi @sskroeker you can't have those two style devices on one account. You can, however, swap them back and forth, if you don't mind a bit more work to do it. Sync the Charge 3, log out and move it out of range, set up Versa 2, log in and step around. Sync, log out and then go back to your Charge 3. It's a bit tricky, but it's the only way to do it.
