07-14-2018
17:32
05:46
MarcoGFitbit
07-14-2018
17:32
05:46
MarcoGFitbit
Trying to set up stats for the elliptical exercise. I select the ones I wanf---steps heart rate and elapsed time. But then when I try to slot them top middle and bottom I can't get them into middle and bottom slots. See picture
Hello @laurebabus, I hope you're doing well, it's great to see you around the Fitbit Community! ![]()
I appreciate you have brought this to my attention. At this moment I would like to suggest you to follow these steps in order to customize your exercise:
I hope this can be helpful, if there's anything else I can do for you, please feel free to reply.
Best AnswerThanks for your response. I tried this and it didn't stick. I tried it again and this time made sure to sync (I use a manual sync). Do you think this will resolve the issue? I hope so!!!
Best AnswerIt did not resolve the issues. The settings return to the default when you restart the versa.
Must be a way to keep the settings. Please keep this open.
Best Answer@laurebabus This is a known bug and the moderator is just gaslighting you. The settings go back to default when you sync. I've had my Versa since release day and it's always done this. Lucky for my I only need to change the bottom stat.
Best AnswerThanks for the info. Thought I was doing something wrong. This is my only issue (hope I don't jinx myself) that I have with the Versa. Guess i can live with it.
Best AnswerProblem still persists. Based on responses from other users this appears to be a bug. Is Fitbit working to fix this? What is the point in having options to set when the settings keep reverting to the default.
Best AnswerHi Fitbit. Can we get some attention paid to this problem? Can't be that hard to fix. All we need is that the Fitbit retain the changed settings!!!! Thanks. Hope this is resolved sometime soon. My only Fitbit issue.
