09-12-2018 10:54
09-12-2018 10:54
When I try to edit the distance on runs it just reverts back to the "predetermined" distance which is usually incorrect, according to the treadmill. Any ETR on when this issue is going to be resolved?
Best Answer09-12-2018 10:58 - edited 09-12-2018 11:00
For one thing it will not record the distance correct on a treadmill to begin with.
If you are holding on to the bars it will not count accurately. Also you not covering an exact distance because you are not moving forward.
Also See this thread by MrMarv
It explains it very well
https://community.fitbit.com/t5/Alta-HR/Step-calculation/m-p/2586363/highlight/true#M22198
But you can go vote for it here. It does say its not currently planned
https://community.fitbit.com/t5/Feature-Suggestions/Editing-Exercises-Distance/idi-p/1669927
Wendy | CA | Moto G6 Android
09-12-2018 11:06
09-12-2018 11:06
That is not what I mean. For example, treadmill clocks me at 2 miles. Fitbit clocks me a 2.2miles. That is fine. When I try to go in and manually change the distance on the run it changes to 2 miles then immediately changes back to 2.2 miles and does not accept my changes. It reverts to what it thinks I ran regardless of editing the run.
Best Answer09-12-2018 13:53
09-12-2018 13:53
What phone do you have @Macanudo? I thought only iOS was able to edit distance.
If course by setting the stride correctly the distance will be recorded correctly.
Your tracker has no way to measure your virtual distance while on a treadmill.
