05-27-2019
15:48
08:51
MarcoGFitbit
05-27-2019
15:48
08:51
MarcoGFitbit
I have done everything I know to do and my NEW Versa will not give me phone calls, text messages, notifications of any kind except to get up and walk! I have done all the help tips and still nothing. What now?
05-27-2019 16:55
05-27-2019 16:55
Same here. Every so often I'll find a short series of texts but without any signal they've come in, no calls, no emails. Worked a bit when I got it last year then quit. I've also tried all the tips.
05-27-2019 20:38
05-27-2019 20:38
Mine is doing the same thing. It has worked perfectly until the last couples of weeks. It doesn’t vibrate either when a text actually comes through.
Best Answer05-28-2019 08:55
05-28-2019 08:55
Hello @Darbry, @jackiebm and @RoxyRoxy have a warm welcome to the Fitbit Community, it's great to have you on board.
I appreciate your participation in the Forums and for sharing your experience with us. I would like to thank you for letting us know you've already tried to troubleshoot this issue on your side.
Tell me, have you restarted your Versa already by pressing and holding the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen. Now, if you have already restarted your Versa, make sure it's not currently in the Do Not Disturb (DND) mode by pressing down the button on the side for 2 seconds, in here check that Notification have been set to ON. If everything seems to working fine, I would like to suggest you to reset Notifications from the Fitbit app following these steps:
Please give these steps a try and keep me posted in case you need anything else.
Best Answer05-28-2019 09:12
05-28-2019 09:12
Best Answer05-30-2019 08:54
05-30-2019 08:54
Hello @Darbry I hope you're doing well, thanks for taking the time to reply and let us know your issue has now been resolved, I'm very glad.
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
