05-13-2018
16:30
11:36
MarcoGFitbit
05-13-2018
16:30
11:36
MarcoGFitbit
I’m trying to set up my new versa. It gets stuck at 5% download for hours and never goes beyond that. I’ve tried Bluetooth on and off. Turning it on and off. Removing the device and adding it back again 3 times. Still never loads past 5%
05-15-2018 11:37
05-15-2018 11:37
Hello @JackieGiles, thanks for joining the Fitbit Community, it's a pleasure for me to welcome you to our family!
Thanks for bringing this to my attention and for letting me know you have already tried to pair your Versa several times. If your Versa is still having trouble setting up, please try the following:
Now, before you begin the firmware update, make sure your watch is plugged into the charger and in range of your Wi-Fi network during the update. For best results, use your home or work Wi-Fi network. If you've never connected your watch to WiFi, see How do I connect my Fitbit watch to Wi-Fi?. If your Versa is having trouble updating with WiFi, please try the following:
If the update fails, restart your mobile device and try to update again. If you your Versa can't update over WiFi follow the on-screen instructions in the Fitbit app to update your watch over Bluetooth instead. Note that firmware updates over Bluetooth may take significantly longer to complete. If the Versa is having trouble updating through Bluetooth try the following:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
