05-17-2018
13:50
09:11
MarcoGFitbit
05-17-2018
13:50
09:11
MarcoGFitbit
Last night i started the installation and left it runing over night and hen i woke up this morning it said installation had failed. I started it again at 5 AM and after 9 hours of installation it failed again. I can not belive that fitbit is selling this with such a huge problem. They should have fixed this before it went on the market.
Best Answer05-21-2018 09:12
05-21-2018 09:12
Hello @zazu06, thanks for joining the Fitbit Community, it's great to have you on board.
Thanks for bringing this to my attention. If your Versa is still having trouble setting up, please try the following:
Now, after setting up your watch you will need to update its firmware. Before doing that, make sure your watch is plugged into the charger and in range of your Wi-Fi network during the update. For best results, use your home or work Wi-Fi network. If you've never connected your watch to WiFi, see How do I connect my Fitbit watch to Wi-Fi?. If your Versa is having trouble updating with WiFi, please try the following:
If the update fails, restart your mobile device and try to update again. If you your Versa can't update over WiFi follow the on-screen instructions in the Fitbit app to update your watch over Bluetooth instead. Note that firmware updates over Bluetooth may take significantly longer to complete. If the Versa is having trouble updating through Bluetooth try the following:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
05-21-2018 14:13
05-21-2018 14:13
I have a Samsung galaxy tab A. Is it compatible with setting up versa?
Best Answer05-22-2018 05:28
05-22-2018 05:28
Hello @Joni71, have a warm welcome to the Fitbit Community, it's great to have you on board. ![]()
Thanks for your participation in the forums, please note that Fitbit is compatible with more than 200 of the most popular Android, iOS and Windows mobile devices. The full list of compatible devices with confirmed compatibility can be found here.
If your device isn’t listed it doesn’t mean it won’t work with a Fitbit tracker or smartwatch. We routinely test new devices to ensure full compatibility with Fitbit devices and the Fitbit App, and are constantly working to confirm compatibility with new phone models. A majority of Android phones running version 4.4 or higher will work with our products, however we cannot guarantee optimal performance on devices for which we have not tested and confirmed compatibility.
I hope this resolves your inquiry, if there's anything else I can do for you, please feel free to reply.
02-17-2020 10:54
02-17-2020 10:54
I m unable to start my fitbit versa 2 watch .after logging it shows make sure it's charged.However it is charged upto 75%
Also will it work with lenovo 6.0 version Android phone
Have tried a lot,still unable to start my watch at the first place
Best Answer02-17-2020 11:07
02-17-2020 11:07
Hi @VanitaSajnani4,
You need to download the Fitbit app on your phone (free app) log into your account (seeing as you can post, you already have an account set up so you can skip that during the setup process), and turn your phone's Bluetooth on. Please be sure that all other Bluetooths are off or removed from the area, this includes other Fitbits.
Once the app is downloaded, open it on your phone and log in. On the left, you should see a small picture of your profile picture. Tap it, you are now in your Account Settings. Next select " Set Up A Device", then find the Versa (1, 2, or Lite depending on which model you have) and follow the prompts.
one cruise ship at a time!
Best Answer02-18-2020 08:25
02-18-2020 08:25
