01-07-2019 04:26
01-07-2019 04:26
What is the best way to track a drumming session while wearing the Versa? I tried all of the standstill excercises (Yoga, Workout, Weights,..), but all of them still register steps taken during my session. A 40-minute drumming session (tracked as 'weights') resulted in +4,121 steps and a distance of 3.85km, while sitting on my chair
I know I can manually log an activity, but I'd like to keep my heart rate measurements to be shown.
Any advice for tracking a drumming session without the activity tracking steps?
Kind regards
Best Answer01-07-2019 06:35
01-07-2019 06:35
Hi, it seems not as a surprise to me that your drumming leads to an increase in steps. The Versa counts your steps by swinging/moving your arms, which happens when you drum. The only way AFAIK to prevent that is to take of your Versa during drumming.
Best Answer01-07-2019 06:48
01-07-2019 06:48
Dear Kuzibri
But you would expect to ignore the 'steps' I took during a weightlifting-exercise.. Weightlifting also requires movement of the arm without actually taking any steps. Even when tracking 'Weights' as exercise while drumming, it counts movement as steps.
Taking my Versa off is indeed the most correct way unfortunately, but drumming can be intensive and being seen as a workout. Sadly I can't register it as such for my daily activity etc.
Thanks anyways!
Best Answer01-07-2019 06:55
01-07-2019 06:55
Hi, weightlifting is something else than drumming in priciple, cause you're making a totally different kind of arm movement that during drumming. Movinf your arms up and down is something else than swinging fore- and backwards as in walking. What you could try is: click on the amount icon on your Fitbit's dashnoard screen, scroll down to exercise, click it and choose one of the activities than comes closest to your drumming and enable it. Maybe that's a workaround, otherwise take your watch off.
Best Answer01-07-2019 06:57
01-07-2019 06:57
I'll give it a try, thanks!
Best Answer01-07-2019 07:00
01-07-2019 07:00
You're very welcome, that's why we are around to be of help.
