I have a Fitbit Versa 2 and until recently it held charge for 2-3 days. Now it holds charge for just 6-8 hours. I have read various community posts and have tried everything there from syncing off to dimming brightness. It is still under warranty. What can I do?
11-25-2019
11:13
04:05
11-25-2019
11:13
04:05
@praving5 Welcome! It's good that the community is growing!
Let me help you with your Versa's battery draining quickly and thank you for troubleshooting this issue. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help improve the battery life.
Let me know how it goes.
