04-18-2022
06:35
08:06
04-18-2022
06:35
08:06
I have my location services on, however, the GPS won’t connect on the versa to track my run. It just says “connecting” but never connects. Any suggestions?
04-18-2022 08:07 - edited 12-31-2023 08:40
Hi there, @DanaVP. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
This may be happing because you're not doing an exercise outdoors, therefore, the GPS connection is lost. Note: If the GPS signal is lost during the exercise, a map might not appear in the Fitbit app.
Verify the following requirements; then try the troubleshooting steps if necessary.
If the issue persists, see if GPS connects after each step:
Hope that helps.
Best Answer04-18-2022 08:07 - edited 12-31-2023 08:40
Hope that helps.
