12-26-2019 10:28
12-26-2019 10:28
I have my Versa 2 set up so that the screen should not turn on unless its touched or the button is pushed. However, at random the screen will turn on for no reason. Could this be a defect? Wondering if I should return and replace?
12-26-2019 10:49
12-26-2019 10:49
Are you sure you have your tracker Settings for Screen Wake on Manual?
12-26-2019 11:38
12-26-2019 11:38
Yes positive its on Manual.
12-26-2019 11:54
12-26-2019 11:54
Try a Restart and do it several times if necessary.
12-30-2019 11:16
12-30-2019 11:16
Restarting did not solve this issue. Probably will take back for an exchange.
12-30-2019 11:25
12-30-2019 11:25
Try a Factory Reset by swiping left to Settings and then About, Factory Reset.
